[mapguide-users] RE: Page cannot be found
rdavid
rdavid.wood at ge.com
Tue Jun 19 09:44:40 EDT 2007
Check the location of your php.ini
1. There is a php.ini found in MapGuideOpenSource\WebServerExtensions\Php
with the path for the php_MapGuideApi.dll needed for the application.
2. You may need to copy this file to your c:\windows dir.
3. Run a php page with phpinfo(); to see where php is looking for the ini
file on your box.
4. After moving the php.ini file provided by the opensource install to
c:\windows dir and restart IIS the application is working.
Jon Rizzo wrote:
> Thanks for the reply Jason. It was the PHP configuration. When I had
> the previous version installed (0.93) I had PHP in a different location.
> I uninstalled it, but there were still some scraps left pointing to the
> old location.
> I have gotten past the Page Not Found error (and I am finally able to
> view phpinfo.php) but now I am getting this error message in login.php:
> Fatal error: Class 'MgException' not found in C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapadmin\login.php on
> line 95
> I thought that I had seen this error mentioned in the old
> MapServerEnterprise mailing list, but I don't have those messages
> anymore. Any idea what might be causing this?
> Jon
> ________________________________
> From: Jason Birch [mailto:Jason.Birch at nanaimo.ca]
> Sent: Tuesday, March 21, 2006 12:17 PM
> To: users at mapguide.osgeo.org
> Subject: RE: [mapguide-users] Page cannot be found
> It sounds like you need to add the bundled php-cgi.exe file to the
> allowed "Web Server Extensions" in IIS administrator. You may also need
> to do this for the MapAgent.exe executable.
> If this has been done, it's possible that the handler (Web Site
> Properties->Home Directory->Application Settings:Configuration) for PHP
> is not set properly.
> Jason
> From: Jonathan Rizzo [mailto:jrizzo at Langan.com]
> Sent: Tuesday, March 21, 2006 07:56
> Subject: [mapguide-users] Page cannot be found
> Hello,
> I recently uninstalled the preview version of MapServer and I am trying
> to get started with RC1 of MapGuide and I'm stuck. Could somebody here
> help me out? I installed MapGuide Server and also installed the Web
> Server Extensions using the IIS Configuration (Windows Server 2003, IIS
> 6, .NET development). I tested the Map Agent, and the XML document was
> returned correctly. However, when I try to test the Site Administrator,
> I go to the URL http://localhost/mapguide/mapadmin/login.php
> <http://localhost/mapguide/mapadmin/login.php> but the browser reports
> "The page cannot be found". I verified that this file exists on the web
> server at this path, and that annonymous access is allowed. In
> addition, if I try to test the Web Server Extensions, I get the server
> error:
> Compilation Error
> Description: An error occurred during the compilation of a resource
> required to service this request. Please review the following specific
> error details and modify your source code appropriately.
> Compiler Error Message: CS0246: The type or namespace name 'OSGeo' could
> not be found (are you missing a using directive or an assembly
> reference?)
> Source Error:
> Line 19: <%@ Import Namespace="System.Collections.Specialized" %>
> Line 20: <%@ Import Namespace="System.IO" %>
> Line 21: <%@ Import Namespace="OSGeo.MapGuide" %>
> Line 22:
> Line 23: <script runat="server">int forDwf=0;</script>
> Source File: C:\Program
> Files\MapGuideOpenSource\WebServerExtensions\www\mapviewernet\ajaxviewer
> .aspx Line: 21
> Can anybody tell me what I have done wrong or what I should check to fix
> this? Thank you for your assistance.
> Regards,
> Jon Rizzo
> Langan Engineering and Environmental Services, Inc.
View this message in context: http://www.nabble.com/Page-cannot-be-found-tf1318088s16610.html#a11195090
