[mapguide-users] Fatal Error
rdavid
rdavid.wood at ge.com
Tue Jun 19 09:48:04 EDT 2007
Check the location of your php.ini
1. There is a php.ini found in MapGuideOpenSource\WebServerExtensions\Php
with the path for the php_MapGuideApi.dll needed for the application.
2. You may need to copy this file to your c:\windows dir.
3. Run a php page with phpinfo(); to see where php is looking for the ini
file on your box.
4. After moving the php.ini file provided by the opensource install to
c:\windows dir and restart IIS the application is working.
Willem Schwarte wrote:
> I have installed Mapguide Open Source and after calling a php file I get
> this message:
> Fatal error: Call to undefined function MgInitializeWebTier() in
> C:\Inetpub\wwwroot\MapserverSites\viewer2\index.php on line 34
> What is wrong here?
View this message in context: http://www.nabble.com/Fatal-Error-tf1499361s16610.html#a11195145
