[mapguide-users] SDF SQL Thematic issue
James Card James.Card at calcad.com
Tue Jun 19 11:08:57 EDT 2007
On Mon, 18 Jun 2007 22:21:19 -0700, Mapstat <mapstat at exemail.com.au> wrote:
> Hi, I am having a lot of trouble with SDF and ODBC connections. I have a
> SDF
> file with 200 polygons which I want to colour thematically from an SQL
> table. I complete the extension and join on a primary key but when they
> display only some of the 200 colour. If I zoom in the colouring seems to
> be
> random ie ones that are coloured then are not. I have run SQL profiler to
> look at the select query passing to SQL and it seems to be limited to 100
> records. Is there any parameters I can change to fix this or is it a bug?
This is a known problem with early builds of MapGuide OS 1.2.0. I think
the RC2 version released yesterday is supposed to correct that problem,
but we are just beginning our testing so I can't verify yet that it has
been fixed.
James Card
209-578-5580
