[mapguide-users] MapGuide Opensource 1.1.0 on CentOS 4.5. installation
Daili mark.tang at thespothk.com
Tue Jun 19 21:49:49 EDT 2007
I got the mistake when I do the make install for the mapguide-1.1.0, the
following is the error:
make install
Making install in DWFTK7.1
make[2]: Entering directory `/usr/local/mapguide-1.1.0/Oem/DWFTK7.1'
Making install in develop
make[3]: Entering directory `/usr/local/mapguide-1.1.0/Oem/DWFTK7.1/develop'
Making install in global
make[4]: Entering directory
`/usr/local/mapguide-1.1.0/Oem/DWFTK7.1/develop/global'
Making install in src
make[5]: Entering directory
`/usr/local/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src'
Making install in dwfcore
make[6]: Entering directory
`/usr/local/mapguide-1.1.0/Oem/DWFTK7.1/develop/global/src/dwfcore'
make[6]: *** No rule to make target `install'.  Stop.
make[6]: Leaving directory
make[5]: *** [install-recursive] Error 1
make[5]: Leaving directory
make[4]: *** [install-recursive] Error 1
make[4]: Leaving directory
make[3]: *** [install-recursive] Error 1
make[3]: Leaving directory `/usr/local/mapguide-1.1.0/Oem/DWFTK7.1/develop'
make[2]: *** [install-recursive] Error 1
make[2]: Leaving directory `/usr/local/mapguide-1.1.0/Oem/DWFTK7.1'
make[1]: *** [install-recursive] Error 1
make[1]: Leaving directory `/usr/local/mapguide-1.1.0/Oem'
make: *** [install-recursive] Error 1
Finally the default mapguideopensource folder only have the folder as
follow:
[root at localhost mapguideopensource]# ls
bin  include  lib  man  share  webserverextensions
The /usr/local/mapguideopensource/server/bin wasn't compilied.
The System is following configuration:
CentOS45
gcc (GCC) 3.4.6 20060404 (Red Hat 3.4.6-8)
Install Apache, PHP, Tomcat (mapguideaptinstaller-1.1.0.tar.gz)
fdo-3.2.0
MapGuide -1.1.0
I only found that the system gcc version is 3.4.6, but the instruction need
the gcc 3.2.3 or 4.0.2. I have attached the installation procedure for you
to trace any mistake I did! :)
http://www.nabble.com/file/p11205910/MG_install.pdf MG_install.pdf
Thanks
View this message in context: http://www.nabble.com/MapGuide-Opensource-1.1.0-on-CentOS-4.5.-installation-tf3949854s16610.html#a11205910
