[mapguide-users] Save user drawn polygon to an existing layer
Simon Pelicon
simon at sl-king.com
Wed Jun 20 02:11:31 EDT 2007
Check this thread
http://www.nabble.com/RE%3A-try-to-update-SDF-FeatureSource...my-code-do
n%27twork.-p9272778s16610.html
Simon Pelicon
www.sl-king.com
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Farah
Sent: Wednesday, June 20, 2007 7:20 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Save user drawn polygon to an existing
layer
Hi Brad,
Nope, Im saving back to the sdf feature source. Im not using an RDBMS.
Regards
Farah
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Wednesday, June 20, 2007 7:49 AM
layer
Is it an RDBMS? Do you need a commit?
Sent: Tuesday, June 19, 2007 8:41 AM
Subject: [mapguide-users] Save user drawn polygon to an existing layer
Hi Folks,
I am trying to draw a polygon on the map and then save it as a feature,
back to a layer of the map ,which exists in the library. I am able to
draw the polygon on map, get its coordinates, create an MgPolygon type
, create the corresponding properties and Insert the polygon in the
layer. I do a client side refresh after the layer is updated. However,
the new polygon does not apear on the map. I am attaching my code (in
jsp) which does the above. Is there anything extra that I need to do so
as to show the feature on map?
Thanks and Regards
Farah Iqbal
Disclaimer by Mail Administrator - Yukthi
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070620/67424817/attachment.html
