[mapguide-users] Save user drawn polygon to an existing layer
Farah
farah at egovernments.org
Wed Jun 20 02:33:40 EDT 2007
Hi Simon,
I did try this out before trying to update my feature source. I did a
GetResourceContent and found that the Read-Only parameter was set to true.
I changed it to false and saved it back using SetResource. I did a
GetResourceContent on the parcels featuresource again to double check that
it was set to false.
Am I missing out anything else?
Regards
Farah
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Simon Pelicon
Sent: Wednesday, June 20, 2007 11:42 AM
To: MapGuide Users Mail List
Subject: RE: [mapguide-users] Save user drawn polygon to an existing layer
Check this thread
http://www.nabble.com/RE%3A-try-to-update-SDF-FeatureSource...my-code-don%27
twork.-p9272778s16610.html
Simon Pelicon
www.sl-king.com
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Farah
Sent: Wednesday, June 20, 2007 7:20 AM
To: 'MapGuide Users Mail List'
Hi Brad,
Nope, Im saving back to the sdf feature source. Im not using an RDBMS.
Regards
Farah
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Wednesday, June 20, 2007 7:49 AM
Is it an RDBMS? Do you need a commit?
_____
Sent: Tuesday, June 19, 2007 8:41 AM
Subject: [mapguide-users] Save user drawn polygon to an existing layer
Hi Folks,
I am trying to draw a polygon on the map and then save it as a feature, back
to a layer of the map ,which exists in the library. I am able to draw the
polygon on map, get its coordinates, create an MgPolygon type , create the
corresponding properties and Insert the polygon in the layer. I do a client
side refresh after the layer is updated. However, the new polygon does not
apear on the map. I am attaching my code (in jsp) which does the above. Is
there anything extra that I need to do so as to show the feature on map?
Thanks and Regards
Farah Iqbal
Disclaimer by Mail Administrator - Yukthi
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070620/0f1cfad5/attachment.html
