AW: [mapguide-users] MrSID problem: RasterIO skipped for odd windowor
buffer size
G.E.O.-Consulting / Hans Mörschell
moerschell at geo.co.at
Wed Jun 20 10:11:56 EDT 2007
Hallo Frank,
thanks for your information.
As you recommended I started a gdalinfo on my MrSID files with the following
result:
the origin MrSID file has a coordinate shift in x direction, that means the
image_xy_origin is for example 10000.125/306999.875, but the sdw file has an
image origin of 760000.125/306999.875;
might there be a problem with the world file ??? how can I make sure, that
the coordinate system of the world file is used ???
Thanks and best regards, Hans
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Frank
Warmerdam
Gesendet: Mittwoch, 20. Juni 2007 15:57
An: MapGuide Users Mail List
Betreff: Re: [mapguide-users] MrSID problem: RasterIO skipped for odd
windowor buffer size
G.E.O.-Consulting / Hans Morschell wrote:
> Hallo,
> I installed the MGOS RC2 (WinXP) with the gdal patches for MrSID, images
> are not displayed.
> I have set the CPL_DEBUG on and I got the following result:
> GDALOpen succeeds as MrSID for all images, but then I get the message:
> RasterIO<> skipped for odd window or buffer size
Hans,
Normally this means a zeroed sized, negatively sized or off-raster area
was requested in the RasterIO(). The zero sized area can easily happen
in real use if you zoom in to a fraction of a pixel.
Were there any preceeding debug messages, perhaps indicating the window?
What is your map view extent? What does gdalinfo report for the mrsid file?
gdalinfo is a commandline utility that is part of FWTools -
http://fwtools.maptools.org/
Best regards,
I set the clouds in motion - turn up | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush | President OSGeo, http://osgeo.org
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
