AW: [mapguide-users] MrSID problem: RasterIO skipped for odd windowor buffer size
Wed Jun 20 10:36:54 EDT 2007
G.E.O.-Consulting / Hans Mörschell wrote:
> Hallo Frank,
> thanks for your information.
> As you recommended I started a gdalinfo on my MrSID files with the following
> result:
> the origin MrSID file has a coordinate shift in x direction, that means the
> image_xy_origin is for example 10000.125/306999.875, but the sdw file has an
> image origin of 760000.125/306999.875;
Hans,
And how is your MapGuide map extent setup?  Based on the sdw extents?
I believe that GDAL will use internal origin information from the .sid
file if available, and only use the .sdw if there is no internal
georeferencing.
Best regards,
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
