AW: AW: [mapguide-users] MrSID problem: RasterIO skipped for oddwindowor buffer size
G.E.O.-Consulting / Hans Mörschell moerschell at geo.co.at
Wed Jun 20 10:42:58 EDT 2007
Hallo Frank,
yes, my MapGuide mapextent is based on the world file because of other
datasets in that coordinate system.
If GDAL uses the internal georeferencing is there a way to control this
behaviour ????
Thanks and best regards, Hans
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org
[mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von Frank
Warmerdam
Gesendet: Mittwoch, 20. Juni 2007 16:37
An: MapGuide Users Mail List
Betreff: Re: AW: [mapguide-users] MrSID problem: RasterIO skipped for
G.E.O.-Consulting / Hans Mörschell wrote:
> Hallo Frank,
> thanks for your information.
> As you recommended I started a gdalinfo on my MrSID files with the
following
> result:
> the origin MrSID file has a coordinate shift in x direction, that means
the
> image_xy_origin is for example 10000.125/306999.875, but the sdw file has
an
> image origin of 760000.125/306999.875;
Hans,
And how is your MapGuide map extent setup?  Based on the sdw extents?
I believe that GDAL will use internal origin information from the .sid
file if available, and only use the .sdw if there is no internal
georeferencing.
Best regards,
I set the clouds in motion - turn up   | Frank Warmerdam,
warmerdam at pobox.com
and watch the world go round - Rush    | President OSGeo, http://osgeo.org
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
