[mapguide-users] 1.2.0 RC1 Unable to Create Unmanaged Feature Source
WCT
stephen.park at westerncorrosion.com
Wed Jun 20 14:07:48 EDT 2007
I'm not able to create an unmanaged feature source with 1.2.0 RC1 & Web
Studio. If I attempt to create new Unmanaged Feature Source I can name the
feature source in Web Studio. But after hitting save there's no output;
resource is not created. I am seeing exceptions in the server logs:
# Log Type: Error Log
# Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
<2007-06-20T11:52:28> Administrator
Error: An exception occurred in the XML parser.
StackTrace:
- MgResourceServiceHandler.ProcessOperation line 80 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\ResourceServiceHandler.cpp
- MgOpSetResource.Execute line 109 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\OpSetResource.cpp
- MgServerResourceService.SetResource line 728 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\ServerResourceService.cpp
- MgRepositoryManager.SetResource line 867 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\RepositoryManager.cpp
- MgRepositoryManager.AddResource line 840 file
- MgResourceContentManager.AddResource line 183 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\ResourceContentManager.cpp
- MgResourceContentManager.PutDocument line 624 file
- MgResourceDefinitionManager.PutDocument line 554 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\ResourceDefinitionManager.cpp
- MgResourceDefinitionManager.ValidateDocument line 429 file
- MgResourceContentManager.ValidateDocument line 556 file
<2007-06-20T11:52:30> Administrator
Error: Resource was not found:
Library://WCT/ArcResources/Data/Unmanaged2.FeatureSource
StackTrace:
- MgOpEnumerateResources.Execute line 121 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\OpEnumerateResources.cpp
- MgServerResourceService.EnumerateResources line 671 file
- MgLibraryRepositoryManager.EnumerateResources line 274 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\LibraryRepositoryManager.cpp
- MgResourceHeaderManager.EnumerateResources line 532 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src\services\resource\ResourceHeaderManager.cpp
- MgResourceHeaderManager.GetParentResources line 1785 file
<2007-06-20T11:57:21> Administrator
Development platform is Win2k3 Server / IIS. Has anyone with this platform
been able to create unmanaged resources using RC1??
View this message in context: http://www.nabble.com/1.2.0-RC1-Unable-to-Create-Unmanaged-Feature-Source-tf3954175s16610.html#a11219127
