[mapguide-users] 1.2.0 RC1 Unable to Create Unmanaged Feature Source
Dave Wilson dave.wilson at autodesk.com
Wed Jun 20 14:59:06 EDT 2007
What login is your server process running under? Does it have network
permissions to the share? Just need to eliminate the obvious potholes.
Regards,
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of WCT
Sent: Wednesday, June 20, 2007 12:08 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] 1.2.0 RC1 Unable to Create Unmanaged Feature
Source
I'm not able to create an unmanaged feature source with 1.2.0 RC1 & Web
Studio. If I attempt to create new Unmanaged Feature Source I can name
the
feature source in Web Studio. But after hitting save there's no output;
resource is not created. I am seeing exceptions in the server logs:
# Log Type: Error Log
# Log Parameters: CLIENT,CLIENTIP,USER,ERROR,STACKTRACE
<2007-06-20T11:52:28> 			Administrator
 Error: An exception occurred in the XML parser.
 StackTrace:
  - MgResourceServiceHandler.ProcessOperation line 80 file
c:\build_bond_area\mapguide_open_source_v1.2\build_17.4\mgdev\server\src
\services\resource\ResourceServiceHandler.cpp
  - MgOpSetResource.Execute line 109 file
\services\resource\OpSetResource.cpp
  - MgServerResourceService.SetResource line 728 file
\services\resource\ServerResourceService.cpp
  - MgRepositoryManager.SetResource line 867 file
\services\resource\RepositoryManager.cpp
  - MgRepositoryManager.AddResource line 840 file
  - MgResourceContentManager.AddResource line 183 file
\services\resource\ResourceContentManager.cpp
  - MgResourceContentManager.PutDocument line 624 file
  - MgResourceDefinitionManager.PutDocument line 554 file
\services\resource\ResourceDefinitionManager.cpp
  - MgResourceDefinitionManager.ValidateDocument line 429 file
  - MgResourceContentManager.ValidateDocument line 556 file
<2007-06-20T11:52:30> 			Administrator
 Error: Resource was not found:
Library://WCT/ArcResources/Data/Unmanaged2.FeatureSource
 StackTrace:
  - MgOpEnumerateResources.Execute line 121 file
\services\resource\OpEnumerateResources.cpp
  - MgServerResourceService.EnumerateResources line 671 file
  - MgLibraryRepositoryManager.EnumerateResources line 274 file
\services\resource\LibraryRepositoryManager.cpp
  - MgResourceHeaderManager.EnumerateResources line 532 file
\services\resource\ResourceHeaderManager.cpp
  - MgResourceHeaderManager.GetParentResources line 1785 file
<2007-06-20T11:57:21> 			Administrator
Development platform is Win2k3 Server / IIS. Has anyone with this
platform
been able to create unmanaged resources using RC1??
View this message in context:
http://www.nabble.com/1.2.0-RC1-Unable-to-Create-Unmanaged-Feature-Sourc
e-tf3954175s16610.html#a11219127
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
