[mapguide-users] RE: 1.2.0 RC1 Unable to Create Unmanaged
FeatureSource
Dave Wilson
dave.wilson at autodesk.com
Wed Jun 20 16:57:09 EDT 2007
Yes you probably need the Studio 2008 Beta. I suspect that WebStudio has
not been updated to accomodate aliases.
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of WCT
Sent: Wednesday, June 20, 2007 2:37 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: 1.2.0 RC1 Unable to Create Unmanaged
FeatureSource
That process is running under local system. I should indicate that I
never
got far enough to be able to define where the resources were stored. I
have
a bunch of .shp files sitting in a local directory outside the library
that
I had intended to use, system has full rights to the directory.
I did run a FileMon to see if there were any filesystem access errors
but
didn't see anything obvious. Also and perhaps unrelated, I did create an
External Files Alias using Mapguide Site Administrator. This does not
show
up anywhere in WebStudio however & I suspect I may need to be using
Mapguide
Studio 2008 Beta to be able to use the resource I defined (???).
Regards,
Steve
Dave Wilson-3 wrote:
> What login is your server process running under? Does it have network
> permissions to the share? Just need to eliminate the obvious potholes.
> Regards,
> Dave
View this message in context:
http://www.nabble.com/1.2.0-RC1-Unable-to-Create-Unmanaged-Feature-Sourc
e-tf3954175s16610.html#a11221736
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
