[mapguide-users] Producing High Resolution images using
renderingservice
Traian Stanev
traian.stanev at autodesk.com
Thu Jun 21 21:38:06 EDT 2007
Both ways are possible. You can specify a higher dpi and also a really large output image size using the web APIs. I have tried both, and there was a bug with labels not taking into account dpi which I think I fixed (but my memory is fuzzy, so may be I didn't fix it).
The limitation is the size of the ouput image in memory, since it needs to be in RAM while rendering the map. I successfully tried a 5000x5000 image, but with 10000x10000 it failed. For an 8.5"x11" image at 600 dpi, you would need to generate a 5100x6600 image which seems doable.
You can also stitch several large image tiles into one big raster as a post processing step, but this would most likely show labeling artifacts at the edges, so I would recommend the monolithic image approach.
Traian
-----Original Message-----
From: mapguide-users-bounces at lists.osgeo.org on behalf of Simon Hope
Sent: Thu 6/21/2007 8:51 PM
To: mapguide-users at lists.osgeo.org
Cc:
Subject: [mapguide-users] Producing High Resolution images using renderingservice
Hi
I’ve got a client who is very interested in developing a site using MapGuide Open source and they have a requirement to produce a map image output into a PDF but the quality of the image is important - i.e. suitable to print on a 600dpi printer.
I’ve looked over the documentation and the Rendering Service seems to cater for map image output however it’s not clear on what quality you can get using this – does anyone have any experience of using the rendering service in this way and could answer these questions:
Can the rendering service be used to output map images at a higher quality by specifying resolution?
If the map image resolution cannot be set –is there any restriction on the size of the image exported using the rendering service (i.e. produce a large image (width x height) and reduce this to fit into the PDF – therefore increasing the quality?
Thanks
Simon
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070621/037dbad3/attachment.html
