[mapguide-users] RE: RDBMS: Can't connect to MySQL Server
Dhirendra Kumar dhirendra.mgos at gmail.com
Fri Jun 22 05:59:36 EDT 2007
Hi Dave,
Thankyou for helping once again. Actually my problem is MySQL and mapguide
connection (FDO). My computer generate IP Address Dyanmically when computer
generates new IP Address then Previous created Layers not display and
generate ERROR!!
An exception occurred in FDO component.
RDBMS: Can't connect to MySQL server on '102.168.1.13' (10060)
Please help me. Anayway to assign MySQL server IP addres Dyanmically ?
regards,
Dhirendra kumar
Dave Wilson-3 wrote:
> What version is your MySQL database? The later FDO only supports version
> 5.022 through about 5.027.
> Regards,
> Dave
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
> Kumar
> Sent: Wednesday, June 20, 2007 11:56 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] RDBMS: Can't connect to MySQL Server
> Hi All,
> Using MGOS 1.1.0, FDO 3.2, MySQL 5.0, WinXP...
> I have success with setting up a MySQL connection for an application on
> my
> local drive. Now that I have 'moved' the application to another machine.
> But
> now i getting a MySQL connection ERROR!!
> The feature source is invalid resion:
> An exception occured in FDO component.
> RDBMS: Can't connect to MySQL Server on '192.168.1.130' (10060)
> I changed new machine IP Address also in Datasource but problem is still
> same. Any way to set IP Address Dynamically ? I think using this way my
> problem get solve and i can move Application to any machine or Dynamic
> enable IP Address machine. But i have not idea how to do this, If anyone
> have idea about this than please help me. Thankyou in advance.
> Regards,
>  Dhirendra Kumar
> http://www.nabble.com/RDBMS%3A-Can%27t-connect-to-MySQL-Server-tf3956684
> s16610.html#a11227075
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/RDBMS%3A-Can%27t-connect-to-MySQL-Server-tf3956684s16610.html#a11248831
