[mapguide-users] RE: RDBMS: Can't connect to MySQL Server
Dave Wilson
dave.wilson at autodesk.com
Fri Jun 22 10:11:08 EDT 2007
If I understand correctly MySQL is on your local machine whose IP
address keeps changing?
Can you try using 127.0.0.1 as the IP address to your MySQL instance?
Dave
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Dhirendra
Kumar
Sent: Friday, June 22, 2007 4:00 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: RDBMS: Can't connect to MySQL Server
Hi Dave,
Thankyou for helping once again. Actually my problem is MySQL and
mapguide
connection (FDO). My computer generate IP Address Dyanmically when
computer
generates new IP Address then Previous created Layers not display and
generate ERROR!!
An exception occurred in FDO component.
RDBMS: Can't connect to MySQL server on '102.168.1.13' (10060)
Please help me. Anayway to assign MySQL server IP addres Dyanmically ?
regards,
Dhirendra kumar
Dave Wilson-3 wrote:
> What version is your MySQL database? The later FDO only supports
version
> 5.022 through about 5.027.
> Regards,
> Dave
> From: mapguide-users-bounces at lists.osgeo.org
> Kumar
> Sent: Wednesday, June 20, 2007 11:56 PM
> Subject: [mapguide-users] RDBMS: Can't connect to MySQL Server
> Hi All,
> Using MGOS 1.1.0, FDO 3.2, MySQL 5.0, WinXP...
> I have success with setting up a MySQL connection for an application
on
> my
> local drive. Now that I have 'moved' the application to another
machine.
> But
> now i getting a MySQL connection ERROR!!
> The feature source is invalid resion:
> An exception occured in FDO component.
> RDBMS: Can't connect to MySQL Server on '192.168.1.130' (10060)
> I changed new machine IP Address also in Datasource but problem is
still
> same. Any way to set IP Address Dynamically ? I think using this way
my
> problem get solve and i can move Application to any machine or Dynamic
> enable IP Address machine. But i have not idea how to do this, If
anyone
> have idea about this than please help me. Thankyou in advance.
> Regards,
> Dhirendra Kumar
http://www.nabble.com/RDBMS%3A-Can%27t-connect-to-MySQL-Server-tf3956684
> s16610.html#a11227075
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
s16610.html#a11248831
