[mapguide-users] RE: Several small lay-out questions
martijni
mis at gemeentehulst.nl
Mon Jun 25 07:23:25 EDT 2007
I did what Jackie said by giving up 0+<property name> (like tanknr) in the
feature label box (theme). Then it shows no decimals in the map indeed, but
I don't want the decimals in the properties. I tried to add it in the
tooltip. Maybe I misunderstood and entered it on the wrong place? :)
bradgisoklah wrote:
> The solution Jackie suggested affects any filed you want to label that is
> numeric. It removes the decimals. Try it.
> Brad
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of martijni
> Sent: Thursday, June 07, 2007 3:46 AM
> To: mapguide-users at lists.osgeo.org
> Subject: Re: [mapguide-users] Several small lay-out questions
> Thanks for your reply Jackie.
> I could be wrong, but what you're saying, shouldn't that be filled in the
> tooltip and has no effect on the properties...?
> Jackie Ng wrote:
>> Regarding the decimals, try using 0+<property name> as your expression.
>> - Jackie
>> martijni wrote:
>>> Hey,
>>> I'm facing some small lay-out problems that I want to get rid of.
>>> As you can see on the screenshot it shows for numbers, six decimals, but
>>> ofcourse it should show none. Same for the date when it shows TIMESTAMP
>>> and the hours after the date, while it isn't supposed to show up.
>>> Further
>>> in the legend it shows a red cross when you chooce to not show a style
>>> of
>>> the geometry, but just the feature label. How can you turn this red
>>> cross
>>> into something like "abc" or at least into something else.
>>> Last question is how to make the selection area bigger for an image.
>>> Like
>>> the symbol you see that's selected on the screenshot, it has to be
>>> clicked totally on the right side of it before it's selected.
>>> http://www.nabble.com/file/p11003274/decimalenendate.jpg
>>> If anyone could help me solve these problems, wich are probably easy for
>>> some experts of you, I would appreciate! :)
>>> Thanks in advance.
>>> Martijn
> http://www.nabble.com/Several-small-lay-out-questions-tf3882273s16610.html#a
> 11004184
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Several-small-lay-out-questions-tf3882273s16610.html#a11284896
