[mapguide-users] Problem installing MGOS 1.2
Stefan Dalakov s.dalakov at mapware.net
Tue Jun 26 10:12:22 EDT 2007
Dependency walker reports about DWMAPI.DLL missing.
Where can I get this file from ?
Regards : Stefan
Kenneth, GEOGRAF A/S wrote:
> I have seen the message "The specified module could not be found" in
> other situations.
> It is usually a problem with a missing Dll.
> You can use a tool called "Dependency Walker" to troubleshoot problems
> (drag the file in question into DW).
> You description makes me belive that the problem is either with
> fcgi_isapi.dll or mapagent.exe, both in the WebTier folder.
> You can also try "uninstall" and then remove the entire
> "MapGuideOpenSource" folder (remember to back up any repositiories
> first!).
> A fresh install should make everything work out fine.
> Regards, Kenneth, GEOGRAF A/S
> Stefan Dalakov skrev:
>> Hi all,
>> I wanted to move to MGOS 1.2 after using MGOS 1.1 for some time.
>> I removed ( reinstalled ) the previous installation but I can't make
>> this work. Tried installing again and again for 10-15 times but no
>> success.
>> I can access mapadmin module - it works ok, and reports that the
>> server is ON. The installation module did not create php association
>> but I fixed this.
>> When I send requests like
>> http://localhost/mapguide/mapagent/mapagent.fcgi?OPERATION=ENUMERATERESOURCES&VERSION=1.0.0&LOCALE=en&RESOURCEID=Library://&TYPE=&DEPTH=-1
>> I get message "The specified module could not be found"
>> If I open http://localhost/mapguide/mapagent/index.html - Web Tier
>> Tests it fails everywhere (same message), except for the "Server
>> admin services"
>> I checked the .fcgi association about 15 times - it seems OK.
>> Mapguide Studio also reports "fail due to unknown reason"
>> I am running WIN XP SP2, with IIS, using PHP as dev. environment.
>> Any suggestions ?
>> Thanks in advance
>> Stefan Dalakov
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
