[mapguide-users] linux wms problem solved.
Jason Birch
Jason.Birch at nanaimo.ca
Fri Jun 29 11:28:06 EDT 2007
larry white wrote:
> a file, 'categories.txt', is in the wrong place.
> it should be in the PROJ_LIB dir
> (.../server/bin/nad), but currently resides in .../server/bin.
That's interesting. Have you filed a bug report on this one yet?
I'm wondering if this is the same reason that the mapagent projection
tests are failing in Win32 with MGOS 1.2.0. What version are you using?
Thanks,
Jason
