[mapguide-users] linux wms problem solved.
larry white
larz at larz.myip.org
Fri Jun 29 11:45:32 EDT 2007
Jason,
no, i haven't filed a report yet. just got it figured out yesterday, so
i wanted to share it with the community first to see if this had come up
previously and i missed it.
uh.... actually, i haven't filed any bug reports yet, and there are a
couple of other things i found recently that probably should also be
reported. will do so sometime today or over the weekend.
i've implemented this fix in the most recent release of mgos - 1.2rc2.
so, perhaps the windows projection test failures are related.
(i've been struggling with this since very early 1.0x versions)
larry white
Senior Systems Analyst
Neomatix Corporation
email: larz at neomatix.ca
url: www.neomatix.ca
Jason Birch wrote:
> larry white wrote:
>> a file, 'categories.txt', is in the wrong place.
>> it should be in the PROJ_LIB dir
>> (.../server/bin/nad), but currently resides in .../server/bin.
> That's interesting. Have you filed a bug report on this one yet?
> I'm wondering if this is the same reason that the mapagent projection
> tests are failing in Win32 with MGOS 1.2.0. What version are you using?
> Thanks,
> Jason
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
