[mapguide-users] linux wms problem solved.
BradM
masonb at dfo-mpo.gc.ca
Fri Jun 29 17:16:58 EDT 2007
now that WMS is working, I would like to see a tool for users to select a
WMS source they want by typing in the url or by selecting from a list, then
the user should be able to select a specific map layer and then select the
order the map layer(s) should be displayed in. Is this possible? Can
anybody help make this tool?
thanks
larry white-6 wrote:
> Jason,
> no, i haven't filed a report yet. just got it figured out yesterday, so
> i wanted to share it with the community first to see if this had come up
> previously and i missed it.
> uh.... actually, i haven't filed any bug reports yet, and there are a
> couple of other things i found recently that probably should also be
> reported. will do so sometime today or over the weekend.
> i've implemented this fix in the most recent release of mgos - 1.2rc2.
> so, perhaps the windows projection test failures are related.
> (i've been struggling with this since very early 1.0x versions)
> larry white
> Senior Systems Analyst
> Neomatix Corporation
> email: larz at neomatix.ca
> url: www.neomatix.ca
> Jason Birch wrote:
>> larry white wrote:
>>> a file, 'categories.txt', is in the wrong place.
>>> it should be in the PROJ_LIB dir
>>> (.../server/bin/nad), but currently resides in .../server/bin.
>> That's interesting. Have you filed a bug report on this one yet?
>> I'm wondering if this is the same reason that the mapagent projection
>> tests are failing in Win32 with MGOS 1.2.0. What version are you using?
>> Thanks,
>> Jason
>> mapguide-users mailing list
>> mapguide-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
View this message in context: http://www.nabble.com/linux-wms-problem-solved.-tf4000152s16610.html#a11367308
