[mapguide-users] GDAL provider for raster...again problem whit
loaddata...
Maciej Skorczewski
maciej.skorczewski at procad.pl
Thu Mar 1 08:56:42 EST 2007
Chris Tallman napisał(a):
> I think you guys having problems with the GDAL provider may have missed
> an important post that I can't seem to find either. But, I think it was
> stated at one point that rasters connected using the GDAL would not
> preview in studio. I believe you have to make a map and web layout and
> view it with a browser to see the aerial images.
no it no work even in webbrowser...raster files who work can see in
preview in Studio...
but...10 minutes ago i check header info of TIF files... and see that
all raster who works have information about this...
mybe i wrong but i have read on list that GDAL ignore GeoTIFF info...and
user must put it manulay...
can you check yours tif header?
my tiff header info
--------THIS file works------------
Output from Display Header
File Name: C:\mapki-rastry\dzialaja\mapka.tif
File Information:
Standard : : TIFF File
Format : : PackBits : Compressed 24 bit RGB data
Pixels per Line : 3227
Number of Lines : 2293
Samples per pixel : 3
File bits per sample : 8
Actual bits per sample : 8
Untiled file
Number of overviews : 0
Scanning device resolution : 200 : lines/inch
Orientation : 4 : Row major order, origin at top left
NO scan line headers : non-scannable file
Packet size (16-bit words) : 0
Free vlt space (16-bit words) : 2000000000
Free packet space (16-bit words) : 2000000000
Raster to UOR matrix:
Unspecified or All Zero Matrix
Raster to World Matrix:
Units: Unknown or Unspecified
amx[ 0]= 0.127, amx[ 1]= 0, amx[ 2]= -6.1595
amx[ 3]= 0, amx[ 4]= -0.127, amx[ 5]= 281.7495
-6.1595 , 281.7495
403.6695 , 281.7495
403.6695 , -9.4615
-6.1595 , -9.4615
Geotiff_Information:
Version: 1
Key_Revision: 1.0
Tagged_Information:
ModelTiepointTag (2,3):
0.5 0.5 0
-6.1595 281.7495 0
ModelPixelScaleTag (1,3):
0.127 0.127 0
ModelTransformationTag (4,4):
0.127 0 0 -6.1595
0 -0.127 0 281.7495
0 0 1 0
0 0 0 1
End_Of_Tags.
Keyed_Information:
End_Of_Keys.
End_Of_Geotiff.
Corner Coordinates:
Upper Left ( -6.159, 281.750)
Lower Left ( -6.159, -9.462)
Upper Right ( 403.670, 281.750)
Lower Right ( 403.670, -9.462)
Center ( 198.755, 136.144)
--------THIS file does't works------------
File Name: C:\mapki-rastry\nie dziala\mapa2.tif
File Information:
Format : : Byte integers (8 bits)
Pixels per Line : 693
Number of Lines : 572
Samples per pixel : 1
Untiled file
Standard color table - type: 2
Color Table Size - Num entries: 256
No GeoTIFF info found
maciek
