[mapguide-users] How to deal with data served by ArcIMS with WMS
Jason Birch
Jason.Birch at nanaimo.ca
Thu Mar 1 12:00:23 EST 2007
WMS has a rather ambiguous interface called "GetFeatureInfo". I don't believe that this is supported within MapGuide though, so anything you did with this would have to be custom code.
As Andy suggests, WFS would give you better access to the features, but I haven't done this myself either.
Jason
From: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Ismael Cams
Sent: Thursday, March 01, 2007 06:48
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] How to deal with data served by ArcIMS with WMS
Hello,
I am completely new to WMS and hope someone can give me some more information about following concern.
In our case the WMS will be served by an ArcIMS. Will it be possible to use the data in the same way as it can be done with other resources (shp, sdf, ...). Is it for example possible to select a feature and get the properties of this feature ? Can the Webextensions API used as it was sdf/shp resource in the repository ?
If not what are the limitations ?
Thanks in advance.
Kind regards,
Ismaël
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070301/f1babe9d/attachment.html
