[mapguide-users] Advice for a beginner!
Hidekazu Shimaji
hshimaji at ybb.ne.jp
Fri Mar 2 21:05:15 EST 2007
I can answer only the first question because I am an IIS user.
> 1. Do I install MapGuide Server first?
Usually, yes. But this is not necesssarily true, because a web server
(including mapguide web server extensions) needs the mapguide (site) server
only when a connection will be created.
Regards,
Hidekazu
--- John Roberts <johnemyr at yahoo.co.uk> wrote:
> Dear All
> I am a beginner with MapGuide Open Source and have a query which I am hoping
> you can help with!
> I have my spatial data loaded in a PostGIS database and I want to install
> MapServer, GeoServer, Deegree and MapGuide Open Source on the same windows
> computer which would allow me to compare and contrast the products.
> I thought that I would therefore install the latest version of Apache HTTP
> server and run all of the products from the same Apache HTTP server.
> What I am not sure about is:
> 2. Do I then install MapGuide Server extensions second? Would I choose
> Manual Configuration and link that to an installation of Apache Tomcat?
> 3. I have looked the Apache site, and the Apache Tomcat 6.0 contains its own
> HTTP server internally. Therefore if I have already installed Apache HTTP
> server, I will have 2 HTTP servers installed. Can I link the Tomcat to the
> independent installation of Apache HTTP server or can I use the HTTP server
> bundled with the Tomcat as a HTTP server in its own right?
> 4. Can MapGuide Open Source read data from PostGIS?
> Any help and advice would be very much appreciated!
> Kind Regards
> John
> Manchester, UK
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
