[mapguide-users] RE: Accessing views/queries in MS Access
Jackie Ng
jackie.ng at aecsystems.com.au
Tue Mar 6 01:07:02 EST 2007
What is that XML (in the linked post) describing? I've never seen it before.
I'm wondering if I do create such an XML document, where am I supposed to
put it? (SetResource ?)
Regards,
- Jackie
Should we not clarify this a bit though...
It is possible to get at a view... just not through the Studio UI...
A view can be created by overriding the schema and pushing the XML
through the MapAgent..
See the following post:
http://www.nabble.com/I-can%27t-see-views-when-I-use-the-FDO-ODBC.-tf189
7275s16610.html#a5202964
Warren Medernach
View this message in context: http://www.nabble.com/Accessing-views-queries-in-MS-Access-tf3232574s16610.html#a9326588
