[mapguide-users] RE: javaviewersample shows jsp source
Dhirendra Kumar
dhirendra.mgos at gmail.com
Wed Mar 14 00:13:19 EDT 2007
Hi Kamil,
Congratulation!!!!!.......... Good news i am happy to read your mail that
you can run succesfully your sample example. Kamil can you tell me your are
from which country and working in which Company. If you get any information
about MGOS then please inform me, Co'uz you know in this field every thing
is depend on help.
Ok By :)
Best Regards
Dhirendra Kumar
Kamil Barbachowski wrote:
> Hi,
> I know where from is this error, I was using old sample for mapGuide 1.0
> but
> sample from file javaviewersample-1.1.zip works fine :)
> Best regards,
> Kamil
> _____
> From: Kamil Barbachowski [mailto:kamil.barbachowski at gmail.com]
> Sent: Tuesday, March 13, 2007 10:23 AM
> To: 'MapGuide Users Mail List'
> Subject: RE: [mapguide-users] javaviewersample shows jsp source
> Hi Farah,
> I've done all those steps plus I've started manually Tomcat server-without
> this I've recived error 503 - Service Temporary Not Aviable ( I use
> boundled
> Apache, Tomcat and PHP ) and right now I've got following sorce error:
> An error occurred at line: 22 in the jsp file:
> /javaviewersample/utilityfunctions.jsp
> Generated servlet error:
> Type mismatch: cannot convert from MgLayerBase to MgLayer
> I haven't modified source code of sample java applicatio.
> Somebody have any idea what could be wrong.
> I will try to run MapGuide Studio as sugested Dhirendra Kumar
> Best regards
> Kamil
> _____
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Farah
> Sent: Tuesday, March 13, 2007 6:06 AM
> Hi Kamil,
> These are the things you need to do:
> 1) Copy the sheboygan .mgp file to the Packages folder.Load the
> sheboygan data using the site admin.
> 2) Copy the javaviewersample code into your www folder.
> 3) Add the following line to your Apache httpd.conf file: JkMount
> /mapguide/javaviewersample/* worker1
> 4) Restart your ApacheMapguide Service
> 5) Try running your sample again.
> farah
> _____
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kamil
> Barbachowski
> Sent: Thursday, March 08, 2007 4:40 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] javaviewersample shows jsp source
> Hi!
> I got a problem getting started with mapguide.
> I've tried to run the sample application for jsp, but
> <http://localhost:8008/mapguide/javaviewersample/ajaxtiledviewersample.jsp>
> gives just jsp source code instead of processing.
> Can somebody help me with that?
> best regards,
> Kamil
> Disclaimer by Mail Administrator - Yukthi
> mapguide-users mailing list
View this message in context: http://www.nabble.com/javaviewersample-shows-jsp-source-tf3369890s16610.html#a9468232
