AW: [mapguide-users] Is there any way to conver dwg files to sdf?
Thomas Grosser grosser at kom21.de
Thu Mar 15 03:18:29 EDT 2007
Dear champingfor,
As you describe i think it would be one way to use tools like SDFLOADER. Or have you an AutoCAD Map available ? There you can save direct to SDF ...
I think the DETE problem is very often - and as we have seen for me it seems to depend on the configuration of your OS ... So i think no real chance to get through ;-)
Mit freundlichen Grüßen
Thomas Grosser
- Geschäftsleitung -
Kom21 - Nürnberg
Großweidenmühlstraße 28
90419 Nürnberg
Tel.: 0911 - 378 33 85
Fax: 0911 - 378 33 86
Web: www.kom21.de
-----Ursprüngliche Nachricht-----
Von: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] Im Auftrag von champingfor
Gesendet: Donnerstag, 15. März 2007 04:01
An: mapguide-users
Betreff: [mapguide-users] Is there any way to conver dwg files to sdf?
Hi,buddy!
	Is there any way to conver DWG files to SDF format, so the data can be used in MapGuide Server?
	As you know, there are a lot of data using DWG format in the past year's enginerring work career. In oder to reuse the data in MapGuide, Maybe you should load the DWG file into MapGuide server using MapGuide Studio .BUT, when I load the dwg file using the Studio, I always get the error message "initalize DETE failed. ", and I found the fact that many other guys get the same error. I reinstall all the MapGuide Serve and Studio many times and it did not work. If you know how to solve this problem,please tell me how. Many appreciate!
	So,since there is no way to solve the DETE problem, Is is possible to find another way to reuse the DWG data? Maybe just like preversion of MapGuide(6.5), using the tool --sdfloader to conver the dwg file to sdf? where can I get the tool? Will it be OK to conver the DWG file to Sdf  which created by AutoCAD 2002 or latter version ?
	If you have another way to reuse you DWG data in MapGuide, please don't hesitate to share your thought.
	Thanks!
        champingfor
        champingfor at 163.com
          2007-03-15
