[mapguide-users] Show/Hide Layers and properties pane
programmatically
Farah
farah at egovernments.org
Thu Mar 15 08:01:40 EDT 2007
Hi Maciej,
Also, what does the method: getIFrameDocument do?
Thanks
farah
-----Original Message-----
Sent: Thursday, March 15, 2007 5:20 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Show/Hide Layers and propertiespane
programmatically
Hi Maciej,
Thanks a lot for that! :-)
Just one clarification though. In the javascript function you are calling:
getIFrameDocument('ifrMap'). What does 'ifrMap' denote here?
Regards
Farah
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Maciej
Skorczewski
Sent: Thursday, March 15, 2007 5:02 PM
To: MapGuide Users Mail List
Subject: Re: [mapguide-users] Show/Hide Layers and propertiespane
programmatically
Hi Farah
i make show/hide TaskArea (right menu), i thing that can help you.
Solution
1. edit files framesetnotaskbar.templ and add this
<frameset name="maparea" cols="*,%s,0,0" frameborder=0 border=0
id='hide_show'>
after change....
<frameset rows="%s,*,%s" frameborder=0 border=0>
<frame name="tbFrame" %s noresize scrolling=no>
id='hide_show'>
<frame name="mapFrame"
src="%s?MAPDEFINITION=%s&TYPE=%s&SHOWLEGEND=%s&SHOWPROP=%s&INFOWIDTH=%s&LOCA
LE=%s&HLTGT=%s&HLTGTNAME=%s&SHOWSLIDER=%s%s"
<frame name="taskFrame" %s noresize frameborder=1 border=1
scrolling=no>
<frame name="formFrame" noresize src="%s">
<frame name="scriptFrame" noresize>
</frameset>
<frame name="sbFrame" %s noresize scrolling=no>
</frameset>
ok so now you add id to frame and you can call this frame by
onclick="javascript:show_hide_right_layer();">
----- function body-------
function show_hide_right_layer()
GetParent().EndMeasure();
getIFrameDocument('ifrMap').getElementById('hide_show').cols="*,0,0,0";
function getIFrameDocument(aID){
var rv = null;
// if contentDocument exists, W3C compliant (Mozilla)
if (top.document.getElementById(aID).contentDocument){
rv = top.document.getElementById(aID).contentDocument;
} else {
// IE
rv = top.document.frames[aID].document;
return rv;
in studio add new invoke script and i body put
getIFrameDocument('ifrMap').getElementById('hide_show').cols="*,200,0,0";
var rv = null;
} else {
// IE
return rv;
maciek
> I need to toggle the visibility of the layers+properties pane,
> programmatically, at the click of a button. How do I go about doing
> this? Also, is there a way to do the same functionality for the map as
> well? Is it possible to turn off the map programmatically?
mapguide-users mailing list
mapguide-users at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/mapguide-users
Disclaimer by Mail Administrator - Yukthi
