[mapguide-users] Feature join and themes
meli-m
meli-m at arcor.de
Thu Mar 15 06:36:42 EDT 2007
Hi Stefan,
if you select the new extension as feature class, can you see any map in the
preview below?
greetings,
Melanie
Stefan Dalakov wrote:
> Hi all,
> I am new to MapGuide OS
> I have an SDF file with polygons and an Access database with
> attribute data and need to create a thematic map based on attribute
> values.
> I uploaded the SDF file and created a data connection thru ODBC to the
> ACCESS database, created a feature join between them with the SDF file
> as a primary source and the data connection as a secondary source,
> linking sdf Key field to the ID field in ACCESS.
> Then I created a new layer using SDF data as Data resource and SDF_new
> extension as feature class. I see fields both from SDF (key,name,url)
> and from ACCESS
> When creating rules for themes, I need to enter expression. Choosing
> property "JoinCtype" (ctype is my field in ACCESS, and Join is the name
> of the feature join) and tryinig to get the unique values I receive the
> message
> "Parameter was not found : JoinCtype"
> Can someone help?
> I am running Mapguide 1.1 on IIS, Win XP and AutoDesk Mapguide Studio 2007
> Thanks
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
View this message in context: http://www.nabble.com/Feature-join-and-themes-tf3238776s16610.html#a9491841
