[mapguide-users] IE, AJAX and Tooltip Images
Brad Nesom
kidsmake6 at msn.com
Thu Mar 15 10:02:29 EDT 2007
Andy,
I remember this problem from a previous thread.
http://www.nabble.com/Properties-Frame-in-Studio-2007---Hyperlinks-tf3126334
s16610.html#a8662120
But I guess you may be right because if I'm not mistaken your site used the
image in the html tooltip.
I wonder if it is associated with html tooltip? And would replicate without
the image also.
Brad
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Andy Morsell
Sent: Tuesday, March 13, 2007 5:08 PM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] IE, AJAX and Tooltip Images
Hi Scott,
I haven't seen that before with non-image HTML in the tooltip. I played
with it for awhile on my end and could not replicate that using HTML <table>
elements. It may have to do with the speed of the data retrieval through
FDO during the individual AJAX call backs. If it is slow enough to respond,
I could see where the behavior may be similar to what I'm seeing with
images.
I did enter a ticket into Trac for this, so hopefully we'll see some
attention to this item in the near future.
Andy
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Scott McFarlane
Sent: Tuesday, March 13, 2007 1:56 PM
Hi Andy,
I experienced the flickering tooltip on IE without referencing an image. In
my case, I was trying to display a two-column <table> element with a few
rows, displaying a set of property/value pairs for the selected object. On
Firefox it works great, on IE the tooltip flashes continuously. Have you
seen this behavior?
- Scott
_____
Sent: Monday, March 12, 2007 12:51 PM
Subject: [mapguide-users] IE, AJAX and Tooltip Images
This was a topic many months (or more like a year) ago. When images are
referenced in the tooltip for a layer, the AJAX viewer with Internet
Explorer can yield some very odd results. If it takes too long for the
image to be returned, say more than 4 or 5 seconds, it's like it tries to
call the image again and then this causes a loop which makes the tooltip to
appear to blink. For an example that I just ran into, see
<http://mapguide.spatialgis.com/mapguide/spokanemaps/>
http://mapguide.spatialgis.com/mapguide/spokanemaps/. When you float your
mouse over one of the camera symbols, a DOT traffic camera image should
appear, but often times results in the above behavior. This works just fine
in Firefox.
Should I enter this as a bug into Trac? I think it had been previously
entered into Project Tracker so I don't want to duplicate anything. Thanks.
Andy Morsell, P.E.
Spatial Integrators, Inc.
<http://www.SpatialGIS.com> http://www.SpatialGIS.com
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070315/1c7407a5/attachment-0001.html
