[mapguide-users] mgservice at 100%
Charly Lebrun charly.lebrun at gmail.com
Tue Mar 20 11:46:18 EDT 2007
George McLean a écrit :
> I am having problems with mgserver.exe running at 100% in Windows XP.
> I tried repair of mgserver and extensions but that did not solve it so
> I uninstalled extensions and server then reinstalled. This did not
> solve the problem either.
> I found the discussion below and have stopped the service in task
> manager and tried running as an application from the command line
> using 'mgserver run'. After starting as an application my CPU is still
> pegged at 100% with mgserver.exe as the process using all the CPU
> Before re-installing I made copy of all the files and folders under
> the C:\Program Files\MapGuideOpenSource folder so I am assuming I have
> everything backed up.
> Should I uninstall and then delete all the repositories etc then
> re-install? Any other suggestions?
> Thanks
> George
Hello Georges,
can you give us your MG version please ? I had this problem with the MG
Entreprise + FDO Oracle provider (tried both the Autodesk and SL-King
providers). Things went smoothly once the MG service pack 1 was installed.
Hope this helps,
Charly
