[mapguide-users] mgservice at 100%
George McLean gmclean at gorge.net
Tue Mar 20 13:14:33 EDT 2007
Hi Charly,
I am using MapGuide Open Source 1.1.0
I think the problem started when I tried to use a version of the MySQL
FDO provider that was incompatible with Mapguide. After I set the
provider dlls back to the version that was working, I rebooted and that
is when the mgservice at 100% started started. I am currently trying to
run the cold backup but it is running at 100% CPU as well so I think I
may have corrupted the repository database. If so I am not quite sure
how to fix it yet so any suggestions would be great!
Thanks
George
Charly Lebrun wrote:
> George McLean a écrit :
>> I am having problems with mgserver.exe running at 100% in Windows XP.
>> I tried repair of mgserver and extensions but that did not solve it
>> so I uninstalled extensions and server then reinstalled. This did not
>> solve the problem either.
>> I found the discussion below and have stopped the service in task
>> manager and tried running as an application from the command line
>> using 'mgserver run'. After starting as an application my CPU is
>> still pegged at 100% with mgserver.exe as the process using all the CPU
>> Before re-installing I made copy of all the files and folders under
>> the C:\Program Files\MapGuideOpenSource folder so I am assuming I
>> have everything backed up.
>> Should I uninstall and then delete all the repositories etc then
>> re-install? Any other suggestions?
>> Thanks
>> George
> Hello Georges,
> can you give us your MG version please ? I had this problem with the
> MG Entreprise + FDO Oracle provider (tried both the Autodesk and
> SL-King providers). Things went smoothly once the MG service pack 1
> was installed.
> Hope this helps,
> Charly
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
