[mapguide-users] Mark objects from diferent layers
Dave Wilson dave.wilson at autodesk.com
Tue Mar 20 13:49:56 EDT 2007
You could define your own SDF and add the objects from the various
layers to that then create a new layer based on this temporary SDF and
style it as you please. This is somewhat similar to the buffer concept
only you have more objects to parse from each layer or possibly a
selection set to add to your own SDF. You may have to query each layer
independently and call a routine to add them to your temporary SDF.
Regards,
Dave
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Claudio
Sanchez
Sent: Tuesday, March 20, 2007 9:10 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Mark objects from diferent layers
Hello, I ve have a map with diferent layers an now I need to paint in
red some objects from diferent layers (these objects are the result of a
process).
To paint objects of one layer I did the following:
First I did a temporal feature source and a temporal layer. This layer
is almost the same that original layer of the objects that I need to
paint.
The diferences are, the new layer use the temporal feature source, a new
feature class and was add the color red in the symbol definition.
Then I add to the map objects of the new feature class in the same x y
that original objects and every works fine.
But now I've have to paint objects from diferent layers and I dont know
how to do this using one temporal layer. is posible to do this using
only one temporal layer?
Thanks in advance, Claudio.
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070320/a86bfc5f/attachment.html
