[mapguide-users] Help converting php parcel example coordinates
George McLean gmclean at gorge.net
Wed Mar 21 18:39:43 EDT 2007
Using Mapguide OS 1.1.0
Map in Nad83 Wisconsin South State Plane Grid, Feet.
I am using $map-GetMapSRS() to produce the string:
PROJCS["WI83-SF",GEOGCS["LL83",DATUM["NAD83",SPHEROID["GRS1980",6378137.000,298.25722210]],PRIMEM["Greenwich",0],UNIT["Degree",0.017453292519943295]],PROJECTION["Lambert_Conformal_Conic_2SP"],PARAMETER["false_easting",1968500.000],PARAMETER["false_northing",0.000],PARAMETER["central_meridian",-90.00000000000000],PARAMETER["latitude_of_origin",42.00000000000000],PARAMETER["standard_parallel_1",44.06666666666666],PARAMETER["standard_parallel_2",42.73333333333333],UNIT["Foot_US",0.30480060960122]]
In fundparcelfunctions.php I am setting the string $ll84 to the string
above and then setting
$sdfParams = new MgCreateSdfParams('LL83', $ll84, $parcelMarkerSchema)
I get a list in the task window of my queried records and the zoom to
works but I do not see the pushpin.jpg on the map.
Is there any way to verify that the features I am adding are really in
the correct coordinate system?  Any other suggestions on how to debug this?
Thanks
George
