[mapguide-users] RE: Save a Web Layout to Session
Tom Fukushima
tom.fukushima at autodesk.com
Wed Mar 21 18:38:51 EDT 2007
Hi Jim,
I'm not sure why the API is failing for you, but WebLayouts can be saved
to the session repository; Studio creates web layouts in the session
repository for layer and map previews.
Tom
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Jim O'Leary
Sent: Wednesday, March 21, 2007 2:05 PM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] RE: Save a Web Layout to Session
Yes, I am able to make a new resource identifier this way, and calling
$resourceId->GetRepositoryType();
tells me that the repository type is "Session".
However, passing that resource id to SetResource() gives:
mginvalidargumentexception
The same call with "Library://pathtoWebLayout.WebLayout" does create the
Web Layout in the repository, so I know the content byte source and
header byte source are valid.
There is no indiction in the documentation that you can use setresource
to save to Session. It appears that you can only save the map to
Session.
Scott McFarlane wrote:
> To save any resource to the session repository, you simply use
> SetResource using the following ResourceID syntax:
> "Session:" + <current session ID> + "//" + <resource name>
> For example, a web layout stored in the session repository might have
> the following ResourceID:
> Session:7f3247f8-0000-1000-8000-000c291ff9df_en//Layout.WebLayout
> Hope this helps!
> Scott
> From: mapguide-users-bounces at lists.osgeo.org
> O'Leary
> Sent: Wednesday, March 21, 2007 11:10 AM
> Subject: [mapguide-users] Save a Web Layout to Session
> I would like to associate a map with a web layout at runtime. I can do
> that by extracting the XML of the web layout using
> GetResourceContent(), replacing the <Map>
> <ResourceId>
> content with the path to the map, and then saving the web layout to
> the repository using SetResource. However, I would like to save the
> new web layout to the Session, and this doesn't work for SetResource.
> The Dev Guide indicates that you save a map to Session by
> $map->Save($resourceService, $mapId);
> However, there appears to be no MGWebLayout class to do the same for a
> web layout. Is there a way to save a web layout to session?
> http://www.nabble.com/Save-a-Web-Layout-to-Session-tf3441428s16610.htm
> l#a959
> 6123
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
http://www.nabble.com/Save-a-Web-Layout-to-Session-tf3441428s16610.html#
a9602044
