[mapguide-users] Search feature of two Layer (Overlapped)
Paul Spencer
pagameba at gmail.com
Thu Mar 22 06:43:16 EDT 2007
Dhirendra,
there is no built in function to do this, but the web api is rich and
you can accomplish this with some scripting in your favourite
scripting language.
You can create a custom command in the task pane that has a single
button 'find'. You need to set up the task in Studio to pass the
selection. In your server-side code, you can get the selection
object from the current map, get the feature (polygon) of the
selection, then open the feature source associated with the voting
booth layer and query it using the polygon as a spatial filter. Then
you can output whatever you like about the voting booths and it will
show up in the task pane again.
There are many examples of this kind of thing, but nothing that does
specifically what you are looking for.
I would guess this would be about 100 lines of code in PHP and a
couple of hours of effort for an experienced mapguide developer. For
someone who is experienced in PHP but not with the mapguide API, it
will take several days to understand how the API works and implement
this properly.
Cheers
Paul
On 22-Mar-07, at 12:50 AM, Dhirendra Kumar wrote:
> Hi All,
> I am devloping Election GIS Application. I want to write query that
> if user
> want to know how many Booth's are in specified village then query
> retrive
> all booth's those are under specified village. i can search any
> feature on
> one layer but here village layer and booth layer's are different
> so, i'll
> have to first select specified village and on the basis of village
> i have to
> search all Booth's. Is this possible to fire query on two layer at
> a time ?
> If yes then how. Please
> suggest me. I am
> waiting...............................................................
> thankyou in Advance
> Dhirendra Kumar
> View this message in context: http://www.nabble.com/Search-feature-
> of-two-Layer-%28Overlapped%29-tf3445472s16610.html#a9608435
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
|Paul Spencer pspencer at dmsolutions.ca |
|Chief Technology Officer |
|DM Solutions Group Inc http://www.dmsolutions.ca/ |
