[mapguide-users] RE: King Oracle: geometry does not display
Per Soderstrom
per.soderstrom at ale.se
Fri Mar 23 05:49:03 EDT 2007
Thanks Haris for your help.
Haris discovered that some of the objects had SDO_GEOMETRY created with NULL
GTYPE (for some unknown reason...). After removing those objects the other
geometries were diplayed. The provider will check for this in future
releases.
haris kurtagic wrote:
> Hi,
> Arbitrary X-Y Coordinates is ok.
> I suppose you have tried to set up initial view extent in Map manually ?
> With Fdo2Fdo you can see which extent will be send to MapGuide ("Fdo
> Toolbox - Fdo Spatial Contexts" ).
> Are you able to read data with Fdo2Fdo "Fdo Toolbox - Fdo Class Data" ?
> In version 0.6.2 there was a problem with compound polygons with
> multiple consecutive arcs which I have fixed ( yet to release), but most
> of line and polygon types should be displayed.
> If you send me sample of your data (dmp file) I can look into it.
> Haris
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Per
> Soderstrom
> Sent: 9. marec 2007 9:39
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] King Oracle: geometry does not display
> Hi,
> We have made a connection using King Provider for Oracle (version 0.6.2)
> in
> MapGuide Studio. The Feature Class looks OK, we can create a layer and
> add
> it to a map without any errors. But we cannot see any geometry, either
> in
> preview or in the viewer. We have tried both linear and polygon data. I
> have
> also looked at the data using Fdo2Fdo and the SDO Metadata DIM INFO
> looks
> OK. The coordinate system is *XY-M* (Arbitrary X-Y Coordinates
> (Meters)).
> Can that be a problem?
> Regards,
> Per Soderstrom
> http://www.nabble.com/King-Oracle%3A-geometry-does-not-display-tf3374407
> s16610.html#a9390406
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/King-Oracle%3A-geometry-does-not-display-tf3374407s16610.html#a9631623
