[mapguide-users] Avoiding Authentication Prompt on Startup
Chris Gountanis
cgountanis at mpower-tech.com
Mon Mar 26 12:44:02 EDT 2007
You need to allow Anon access within IIS to not get the Windows Auth box
popping up on you not to be confused with MapGuides Auth box which it seems
you might have covered already.
Chris
_____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Buscher, Shane
Sent: Monday, March 26, 2007 11:22 AM
To: MapGuide Users Mail List
Subject: [mapguide-users] Avoiding Authentication Prompt on Startup
I can't seem to find a way to avoid users being prompted to authenticate
when they open up a MapGuide site for the first time. After that, they
aren't prompted again. You can cancel out of the authentication and bypass
it, but this isn't very elegant. I'm using the DWF Viewer with .NET/iis 6,
and have the MapGuide virtual directories set to windows authentication
(anonymous access unchecked). I am authenticating on my default page with
the code snippets below, then passing the session Id and web Layout to the
dwf viewer. If anyone has a solution/workaround, I'd much appreciate it.
Dim site As New MgSite()
Dim userInfo As New MgUserInformation(AppSettings("mgLogin"), _
AppSettings("mgPassword"))
site.Open(userInfo)
Dim SessionId As String = site.CreateSession()
Dim WebLayout As String = AppSettings("webLayout")
<iframe id="ViewerFrame" width="100%" height="100%" frameborder="0"
src="/mapguide/mapviewernet/dwfviewer.aspx?SESSION=<%= SessionId
%>&WEBLAYOUT=<%= webLayout %>" >
</iframe>
Regards,
Shane
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070326/7be2f52d/attachment-0001.html
