[mapguide-users] RE: Bypassing initial view at startup
FGoulet
gouletf at dfo-mpo.gc.ca
Tue Mar 27 15:59:35 EDT 2007
Thanks.
Looks rather complicated but I will read to learn more about changing the
web layout for a session.
Scott McFarlane wrote:
> FGoulet,
> You can set the initial view in the Web Layout, and that will override the
> initial view set in the Map Definition. If you want to do this
> dynamically,
> (programmatically) then you need to get the web layout XML, modify the XML
> to add the <InitialView> tag, then store the web layout in the Session
> repository and display that in your browser.
> For example, the XML for a web layout with an InitialView might look like
> this:
> <?xml version="1.0" encoding="utf-8"?>
> <WebLayout xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xmlns:xsd="http://www.w3.org/2001/XMLSchema"
> xsi:noNamespaceSchemaLocation="WebLayout-1.0.0.xsd">
> <Title>Sheboygan Map</Title>
> <Map>
> <ResourceId>Library://Samples/Sheboygan/Maps/Sheboygan.MapDefinition</Resour
> ceId>
> <InitialView>
> <CenterX>-87.72</CenterX>
> <CenterY>43.77</CenterY>
> <Scale>2000</Scale>
> </InitialView>
> <HyperlinkTarget>TaskPane</HyperlinkTarget>
> </Map>
> </WebLayout>
> - Scott
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of FGoulet
> Sent: Thursday, March 22, 2007 4:07 PM
> To: mapguide-users at lists.osgeo.org
> Subject: [mapguide-users] Bypassing initial view at startup
> Hi,
> When the MapGuide Viewer start, is there a way to zoom to an extent other
> than what is it defined in the map layout initial view?
> I know I can zoom after the map first apprears but I would really like to
> bypass the initial view for a better user experience.
> Thanks
> http://www.nabble.com/Bypassing-initial-view-at-startup-tf3450031s16610.html
> #a9623015
> Sent from the MapGuide Users mailing list archive at Nabble.com.
> mapguide-users mailing list
View this message in context: http://www.nabble.com/Bypassing-initial-view-at-startup-tf3450031s16610.html#a9699933
