[mapguide-users] linking libcurl.so.2 to libcurl.so.3 ?
Walt Welton-Lair walt.welton-lair at autodesk.com
Wed Mar 28 20:09:24 EDT 2007
What does the libcurl.so symlink point to?  It should look something
like the following:
-rw-r--r--  1 284100 Dec 12  2005 libcurl.a
lrwxrwxrwx  1     16 Mar 13 22:24 libcurl.so -> libcurl.so.3.0.0
lrwxrwxrwx  1     16 Mar 13 22:24 libcurl.so.3 -> libcurl.so.3.0.0
-rwxr-xr-x  1 214952 Dec 12  2005 libcurl.so.3.0.0
This is from a Fedora 4 machine, and I run MG OpenSource on it w/o
problems.
Walt
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Casey
Townsend
Sent: Thursday, March 29, 2007 2:02 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] linking libcurl.so.2 to libcurl.so.3 ?
I'm trying to run MapGuide Enterprise on centos4.4
<http://www.centos.org/> which is the equivalent to RHEL 4.
Yes, I know it is setup for RHEL 3, but the only problem seems to be
that libcurl.so.2 has been replaced by libcurl.so.3. Reading the cURL
list - the API didn't change, mostly just deprecated packages were
removed.
I tried creating a symlink in /usr/lib/ from libcurl.so.2 to
libcurl.so.3 and when that didn't work to libcurl.so.3.0.0. That didn't
work either.
Any suggestions (other than use RHEL 3 !) ?
Casey Townsend
System Administrator
Department of Transportation
City of Tucson
casey.townsend at tucsonaz.gov
520-837-6663
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
