[mapguide-users] Suitable Database for MapGuide using FDO
Dhirendra Kumar dhirendra.mgos at gmail.com
Sat Mar 31 00:36:05 EDT 2007
Hi Paul,
Thnakyou for suggestiing, as per your suggestion i am studying MapGuide API.
I hope i can solve my problem. If you get any information related to my
Application or any thing new then please inform me.
Regards,
Dhirendra Kumar
Paul Spencer-5 wrote:
> Dhirendra,
> I said YOU should build two applications.  I haven't built anything
> like what you are attempting ... well, that's not quite true, but I'm
> not able to share code at this point.  There are examples for
> MapGuide that show how to do this kind of thing somewhere, and the
> documentation has some good examples too.
> Paul
> On 30-Mar-07, at 12:56 AM, Dhirendra Kumar wrote:
>> Hi Paul spencer,
>> Thankyou for your replay, and right now i am studying MGOS Feature
>> API. Paul
>> Spencer you mentioned in your message that you also  build two
>> applications
>> like my Application. So,  if you don't mind then can you send me
>> some PHP
>> Code sample for updating Attribute of SHP file Because to see code
>> i can
>> understand better and Applay in my project fastly. I'll try to
>> follow your
>> given Psuedo code. Thankyou
>> Regards
>> Dhirendra Kumar
>>> Krunoslav, I don't think this is a particularly fair set of comments
>>> to make.  Everyone has to start somewhere, and in open source we
>>> (should try to be) particularly friendly to new users and help them
>>> out.  In some cases, a little research is in order before coming to
>>> the list (that is what FAQs are for).  I think this particular
>>> question is valid for someone new to MapGuide OS.  New users become
>>> experienced users and can help out ...  Also new users tend to ask
>>> the 'obvious', 'dumb' questions that force you to think about things
>>> in a different way and often improve a project :)
>>> Dhirendra, MapGuide provides a rich API for editing feature sources
>>> under MapGuide's management.  SHP and SDF files can easily be updated
>>> if you are willing to spend some time learning the Feature API.
>>> For your case, I would build two applications that point to the same
>>> map.  The first would be public facing and just provide a view of the
>>> data.  The second would be for entering new information into the
>>> voting data source.  You can create a PHP page as a custom task and
>>> add it to an application.  The PHP page would have (at least my first
>>> idea of how to do this) a form with an input that is populated from
>>> the voting station names and a series of input values that allow you
>>> to enter in new values for each of the fields (i'm guessing number of
>>> votes per candidate or something like that).
>>> The psuedo code would look something like:
>>> open map from session
>>> get voting layer from map
>>> get feature source id from voting layer
>>> if form was submitted:
>>>    get feature id from form variables
>>>    get field values from form variables
>>>    create new MgUpdateFeatures
>>>    execute MgUpdateFeatures
>>>    force refresh on voting layer
>>> output form header
>>> output voting station select:
>>>    open feature source id
>>>    select all features
>>>    loop over features:
>>>      output option with value = feature unique id (required above)
>>> and station name
>>> close form
>>> You could also output javascript and arrays of voting stations by
>>> region and have two selects, one for regions that updates the voting
>>> station select with the appropriate values if you have a lot to
>>> manage.
>>> Cheers
>>> Paul
>>>>> Hi All,
>>>>> I am devleoping Election GIS System using MapGuide and my client
>>>>> requirment is to update data during run time. Example :- Suppose
>>>>> today we
>>>>> have 30 booths in one district and next year it would increase by
>>>>> 10. then
>>>>> how will i display on layer, right now i have only one solution of
>>>>> this
>>>>> problem is that create new SHP file and place in MapGuide
>>>>> manually. But my
>>>>> client requirment is updation should be Run time automatically.
>>>>> Is it
>>>>> possible using FDO ? if yes then which database will be suitable
>>>>> for
>>>>> MapGuide ? and please give me detail how will i use FDO in
>>>>> MapGuide.
>>>>> Please help me. I am
>>>>> waiting.....................................................
>>>>> Thankyou in Advance
>>>>> Dhirendra Kumar
>>>> I don't mean to be offensive, but it seems to me like you took a
>>>> task which
>>>> is too complicated for you. Election GIS system is not easy at all,
>>>> and you
>>>> are newbie here just like me. To be honest, I would never accept
>>>> such task
>>>> with so little knowledge about system I work with. You're asking
>>>> every day
>>>> few questions and waiting, without reading the documentation, like
>>>> someone
>>>> will do all the work for you. Again, I don't mean to be offensive,
>>>> but I
>>>> think you should consider another solution, or give it to someone
>>>> who knows
>>>> what he's doing.
>>>> View this message in context: http://www.nabble.com/Suitable-
>>>> Database-for-MapGuide-using-FDO-tf3484536s16610.html#a9727811
>>>> Sent from the MapGuide Users mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> mapguide-users mailing list
>>>> mapguide-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapguide-users
>>> |Paul Spencer                          pspencer at dmsolutions.ca    |
>>> |Chief Technology Officer                                         |
>>> |DM Solutions Group Inc                http://www.dmsolutions.ca/ |
>> Database-for-MapGuide-using-FDO-tf3484536s16610.html#a9747282
View this message in context: http://www.nabble.com/Suitable-Database-for-MapGuide-using-FDO-tf3484536s16610.html#a9764248
