[mapguide-users] RE: Web Studio error
Zak James zak4ms at gmail.com
Sat Mar 31 11:30:13 EDT 2007
You might want to look at this thread which covers some of the issues
with using webstudio with a .NET install:
http://lists.osgeo.org/pipermail/mapguide-users/2006-September/003100.html
Unfortunately, we still haven't done anything to take care of this
problem but I hope to have time to resolve it soon.
zak
On 3/30/07, citycourtenay <mwcourtenay at yahoo.com> wrote:
> Yes, It's probably a PHP error, I chose the default install for .NET and not
> PHP but I quess PHP still gets installed in order to use the admin tools ?
> The IIS Web server extentions are in place, and set for "allowed" .
> I'm curious to hear how your install goes.
> Yes Courtenay, B.C. (I think I might change that name :)
> JasonBirch wrote:
> > It might be a PHP error.  It might also be an IIS setting.  It's hard to
> > tell :)
> > In your IIS admin console, do you have Web Service Extensions for
> > FastCGI and PHP configured and set to Allowed?
> > I'm about to do an install on a 2003 SP2 (not R2) server; I'll be able
> > to help more once this is done.
> > I have to ask:  citycourtenay:  Courtenay BC?
> > Jason
> > -----Original Message-----
> > From: citycourtenay
> > Subject: [mapguide-users] Web Studio error
> > If I attempt :
> > http://localhost/mapguide/webstudio
> > I get the default webstudio ajax login dialog box with the user/pass
> > already filled it along with the above URL but when I try login I get a
> > IE dialog box stating " The URL you requested does not exist, please try
> > again"
> > running on IIS 6, windows 2003 std server sp 2, IE 6 Installed the .NET
> > web extentions and checked all the php settings with the manual,
> > although none of the PHP pages will display either, I get a "Page not
> > found". so it seems likely it is a php problem ?
> > mapguide-users mailing list
> > mapguide-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapguide-users
> View this message in context: http://www.nabble.com/Web-Studio-error-tf3494506s16610.html#a9761700
> Sent from the MapGuide Users mailing list archive at Nabble.com.
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
