[mapguide-users] .MPG Package
Kenneth ks at geograf.dk
Wed May 2 07:08:31 EDT 2007
First of all, you should NOT use the repositories library for storage of
your own files (eg. packages).
In fact you should consider everything below the Repositories folder a
"black box". All files in this folder is considered to be managed by
MapGuide Server, and should not be modified from elsewhere. Make sure
that you do not use this path.
To change your path, edit the file located
in
C:\Program Files\MapGuideOpenSource\Server\Bin\Serverconfig.ini
In this file, find the line starting with:
PackagesPath =
then make sure that the line is now:
PackagesPath = C:\Program Files\MapGuideOpenSource\Server\Packages
Save the file and make sure that the above mentioned folder exists and
is read/writeable by the MapGuide service.
Then restart the mapguide service (or just reboot the machine).
Regards, Kenneth, GEOGRAF A/S
Feras Ahmed wrote:
> Dear Kenneth...
> My problem is that i put the folder (which contains the shapefiles )
> in C:\Program Files\MapGuideOpenSource\Server\Repositories\Library
> and when i start managing packages i got that mapguide can't find the
> specified folder
> so what is the problem?
> Thanks..
> */Kenneth <ks at geograf.dk>/* wrote:
>     feras wrote:
>     > HI..
>     > I 'am new to mapguide So Can anybody help me to make .Mpg
>     package in a list
>     > of instruction. because i got tired of this.
>     > Thanks.
>     Open http://localhost:8008/mapguide/mapadnin/login.php
>     Type username/password (default is Administrator/admin) and click
>     "Log in".
>     Click on "Manage Packages"
>     On the left side of the screen, type the path to the top most
>     folder, eg:
>     Entire server: Library://
>     Only Redding: Library://Redding
>     Type something meaningfull in the box "Resulting package name",
>     eg: "my
>     package.mpg".
>     Click the "Make button".
>     The package will be placed in the Package directory (usually
>     C:\Program
>     Files\MapGuideOpenSource\Server\Packages).
>     If you use Linux, or have changed the default directory, Click
>     "Manage
>     Packages" on the right, and "Configure Packages Directory" on the
>     right.
>     You can now see what the package directory is configured to be.
>     All packages created by the MapGuide Server will be placed in this
>     folder.
>     To load a package, place it in this folder, login to the MapGuide
>     Server
>     Admin as described above.
>     Click "Manage packages" on the right, select the package on the list
>     (bottom, left).
>     Then click "Load Package".
>     Note that only files with the "mgp" file extension will show up in
>     the list.
>     _______________________________________________
>     mapguide-users mailing list
>     mapguide-users at lists.osgeo.org
>     http://lists.osgeo.org/mailman/listinfo/mapguide-users
> Ahhh...imagining that irresistible "new car" smell?
> Check out new cars at Yahoo! Autos.
> <http://us.rd.yahoo.com/evt=48245/*http://autos.yahoo.com/new_cars.html;_ylc=X3oDMTE1YW1jcXJ2BF9TAzk3MTA3MDc2BHNlYwNtYWlsdGFncwRzbGsDbmV3LWNhcnM->
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070502/ddf5b5db/attachment.html
