[mapguide-users] Basic Approach
andresch at iway.na andresch at iway.na
Wed May 2 12:14:46 EDT 2007
Thank you all for the feedback
I did manage to setup the basic web map. I do believe the best way to
go would be to upload the shp files to POSTGIS. Postgresql also hase a
command to export the data back to shp. Some coding probaly required..
Question: what is the purpose of the site adminsitrator function, will
I not be able to use that to handle the access levels.
Also note that the data will be updated from time to time, which will
be easier if in a databse.
I will be trying to setup the PostGIS links tomorrow.
Customizing the default AJAX viewer screen, what is involved and which
files do I need to edit??
Andre Schoonbee
Project Manager
Bull Information Technology
Tel: +264 61 2092844
Mobile: +264 81 278 5800
Skype: andreschoonbee
MSN: apschoonbee at msn.com
----- Original Message -----
Date: Tuesday, May 1, 2007 6:17 pm
Subject: RE: [mapguide-users] Basic Approach
> > Im not sure that there is currently write support for the Shape
> provider
> There is write support, but not create support (as far as I know).
> I
> believe that you would have to maintain "dummy" shapefiles
> (possibly one
> per geometry type), and on download request copy to a temporary
> location, apply a schema and populate using the Feature Service, then
> zip them together and provide the user a link.  It's not easy but
from
> an initial investigation it appears that it's possible.
> > There is support for PostGIS, afaik.
> Yes, through the OGR provider.  As well, a native PostGIS provider
> should be available for beta testing soon.  If anyone already has
> PostGIS set up and working with OGR and wants to test the new
provider
> in a somewhat unstable state, drop me a note offline.
> > Once this is done, you will need a pdf creater component to
> insert the
> image.
> PHP has a PDF library available through PECL:
> http://www.php.net/pdf
> Which allows you to insert images:
> http://www.php.net/manual/en/function.pdf-load-image.php
> Jason
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
