[mapguide-users] patch for Mouse WheelZoom,
set scale and image on loading map in Ajax
web
web at infogeo.ch
Mon May 7 03:17:44 EDT 2007
Hi all,
just wanted to add somethig to the discussion of Mon Apr 2 17:49:22 EDT 2007.
Reference: http://lists.osgeo.org/pipermail/mapguide-internals/2007-April/001122.html
Display the rotating icon sounds good when the page is loading. I've added an effect which blurs the map (with a transparent div) when loading. With the rotating arrow, this is a nice effect.
All you have to do is opening the [ajaxmappane.templ]
About line 3047:
<div>
<div id="mapSpace">
<div id="tilePlanes">
</div>
<div id="img1" style="overflow: hidden;">
<img class="mapImage" id="mapImage1" style="visibility: hidden;" >
<img class="mapImage" id="mapImage2" style="visibility: hidden;" >
</div>
<!-- Setting a transparent div to display when the page is loading, with the logo rotating -->
<div id="maskTransp" style="display:none; background-color:#FFFFFF; position:absolute; width:100%%; top:0; left:0; height:100%%; filter:alpha(opacity=60); -moz-opacity:0.6; opacity: 0.6; z-index: 1;" ></div>
</div>
<div id="overlay" style="display:none; visibility: hidden; position: absolute; top: 0px; left: 0px;"></div>
</div>
then, about line 1360:
else
var frmParent = parent.frames ["tbFrame"];
var objDivRefresh = frmParent.document.getElementById("divRefresh");
var objDivTransparent = document.getElementById("maskTransp");
if(objDivRefresh!=null){ objDivRefresh.style.display='block'; }
if(objDivTransparent!=null){ objDivTransparent.style.display='block'; }
panX1 = extX1 = resp.lowerLeft.X;
panY1 = extY1 = resp.upperRight.Y;
panX2 = extX2 = resp.upperRight.X;
and about line
imgdiv.style.display = "block";
if(safari)
curimg = (curimg == "mapImage1"? "mapImage2": "mapImage1");
if(objDivRefresh!=null){ objDivRefresh.style.display='none'; }
if(objDivTransparent!=null){ objDivTransparent.style.display='none'; }
return false;
function OnAlternateImageLoaded() {
For the rotating arrow, do not forget, if it is not done, to:
Set the div in toolbar.templ
about line 232
<body class="Toolbar" onload="InitDocument()" leftmargin=10 topmargin=0 rightmargin=0 bottommargin=0 marginwidth=0>
<div id="divRefresh" name="divRefresh" class="cssRefresh"><img src="../phpviewersample/images/spinner_notext.gif"><img src="../phpviewersample/images/text_spinner.gif"></div>
<span id="ToolbarContent"><td></td></span>
<div class="TextMetricsDiv" id="TextMetricsDiv"><span class="TextMetrics" id="Metrics"></span></div>
and in the css section:
div.cssRefresh
position: absolute;
right:0px;
top:0px;
Rémy
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070507/c06870fe/attachment-0001.html
