SPAM-LOW: Re: [mapguide-users] Error in ASP AjaxViewer application (update)
Kallitsa, Antonia a.kallitsa at info.quest.gr
Mon May 7 09:52:20 EDT 2007
Hello Andy,
I am sorry I am using your e-mail address. I found this link on the
osgeo site :
http://lists.osgeo.org/pipermail/mapguide_users/2006-September/002967.ht
ml
And since I have the same problem I am wondering if you could help me
out with this. I have encountered the problem in the studio after
loading the data and when I try to create the map. The problem is
described as ( I quote from the osgeo site, I get the exact same
message)
"FYI - An update to this: I thought I would try replacing the 'long'
path to
the .aspx --> aspnet_isapi.dll mapping with the 'short' one. This
resulted a
different error that runs as follows:
"Server Error in '/mapguide/mapviewerajax' Application.
Failed to access IIS metabase.
Description: An unhandled exception occurred during the execution of the
current web request. Please review the stack trace for more information
about the error and where it originated in the code.
Exception Details: System.Web.Hosting.HostingEnvironmentException:
Failed to
The process account used to run ASP.NET must have read access to the IIS
metabase (e.g. IIS://servername/W3SVC <IIS://servername/W3SVC> ). For
information on modifying
metabase permissions, please see
http://support.microsoft.com/?kbid=267904.
<http://support.microsoft.com/?kbid=267904.>
Source Error:
An unhandled exception was generated during the execution of the current
web
request. Information regarding the origin and location of the exception
can
be identified using the exception stack trace below.
Stack Trace:
[HostingEnvironmentException: Failed to access IIS metabase.]
   System.Web.Configuration.MetabaseServerConfig.MapPathCaching(String
siteID, VirtualPath path) +690
System.Web.Configuration.MetabaseServerConfig.System.Web.Configuration.I
Conf
igMapPath.MapPath(String
siteID, VirtualPath vpath) +9
   System.Web.Hosting.HostingEnvironment.MapPathActual(VirtualPath
virtualPath, Boolean permitNull) +174
   System.Web.CachedPathData.GetConfigPathData(String configPath) +398
   System.Web.CachedPathData.GetConfigPathData(String configPath) +263
   System.Web.CachedPathData.GetVirtualPathData(VirtualPath virtualPath,
Boolean permitPathsOutsideApp) +166
System.Web.Configuration.RuntimeConfig.GetLKGRuntimeConfig(VirtualPath
path) +187
Version Information: Microsoft .NET Framework Version:2.0.50727.42;
ASP.NET
Version:2.0.50727.42"
You went on resolting the other issue this guy had but I am so
interested in the solution for this problem....
Thank you very much for your help on this matter!!
Tania Kallitsa
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070507/9e1ed60c/attachment.html
