SPAM-LOW: Re: [mapguide-users] Error in ASP AjaxViewer application(update)
Andy Morsell amorsell at spatialgis.com
Mon May 7 15:23:45 EDT 2007
That was awhile ago and I do not recall what ultimately fixed the problem.
I most likely Googled the error message and tried some of the fixes
recommended in the various IIS / .NET user forums.
Sorry that I can't be of more help.
Andy
  _____
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kallitsa,
Antonia
Sent: Monday, May 07, 2007 6:52 AM
To: mapguide_users at lists.osgeo.org
Subject: SPAM-LOW: Re: [mapguide-users] Error in ASP AjaxViewer
application(update)
Hello Andy,
I am sorry I am using your e-mail address. I found this link on the osgeo
site :
http://lists.osgeo.org/pipermail/mapguide_users/2006-September/002967.html
And since I have the same problem I am wondering if you could help me out
with this. I have encountered the problem in the studio after loading the
data and when I try to create the map. The problem is described as ( I quote
from the osgeo site, I get the exact same message)
"FYI - An update to this: I thought I would try replacing the 'long' path to
the .aspx --> aspnet_isapi.dll mapping with the 'short' one. This resulted a
different error that runs as follows:
"Server Error in '/mapguide/mapviewerajax' Application.
Failed to access IIS metabase.
Description: An unhandled exception occurred during the execution of the
current web request. Please review the stack trace for more information
about the error and where it originated in the code.
Exception Details: System.Web.Hosting.HostingEnvironmentException: Failed to
The process account used to run ASP.NET must have read access to the IIS
metabase (e.g.  <IIS://servername/W3SVC> IIS://servername/W3SVC). For
information on modifying
metabase permissions, please see
<http://support.microsoft.com/?kbid=267904.>
Source Error:
An unhandled exception was generated during the execution of the current web
request. Information regarding the origin and location of the exception can
be identified using the exception stack trace below.
Stack Trace:
[HostingEnvironmentException: Failed to access IIS metabase.]
   System.Web.Configuration.MetabaseServerConfig.MapPathCaching(String
siteID, VirtualPath path) +690
System.Web.Configuration.MetabaseServerConfig.System.Web.Configuration.IConf
igMapPath.MapPath(String
siteID, VirtualPath vpath) +9
   System.Web.Hosting.HostingEnvironment.MapPathActual(VirtualPath
virtualPath, Boolean permitNull) +174
   System.Web.CachedPathData.GetConfigPathData(String configPath) +398
   System.Web.CachedPathData.GetConfigPathData(String configPath) +263
   System.Web.CachedPathData.GetVirtualPathData(VirtualPath virtualPath,
Boolean permitPathsOutsideApp) +166
   System.Web.Configuration.RuntimeConfig.GetLKGRuntimeConfig(VirtualPath
path) +187
Version Information: Microsoft .NET Framework Version:2.0.50727.42; ASP.NET
Version:2.0.50727.42"
You went on resolting the other issue this guy had but I am so interested in
the solution for this problem..
Thank you very much for your help on this matter!!
Tania Kallitsa
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070507/8e5c6fd7/attachment.html
