[mapguide-users] RE: try to update SDF FeatureSource...my
codedon'twork.
Zak James
zak4ms at gmail.com
Fri May 11 10:34:08 EDT 2007
Jim,
I'm pretty sure the SHP provider gives read only access which would
explain why it doesn't support the ReadOnly parameter.
If you want to change an underlying SHP, you will have to delete the
resource data and point the FeatureSource at an updated file.
SDF is a more flexible alternative for most things you might want to
do with SHP.
zak
On 5/10/07, Jason Birch <Jason.Birch at nanaimo.ca> wrote:
> Hi Jim,
> I'm afraid that I don't have any experience working with shapefiles. It
> could be that they work differently than SDF...
> Jason
> -----Original Message-----
> From: Jim O'Leary
> Subject: [mapguide-users] RE: try to update SDF FeatureSource...my
> codedon'twork.
> I have tried adding a <Parameter> tag for ReadOnly and also tried adding
> a parameter for <Name>file</Name>. I am able to set the resource, but
> then MapGuide cannot find it, or it complains about the readonly in the
> connection. I made this package from MGE 1.0.0.17864.
> I have the same problem writing to an imported package, so would like to
> change the readonly. Any suggestions?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
Zak James
Applications and Software Development
DM Solutions Group Inc.
http://www.dmsolutions.ca
