[mapguide-users] .Net and Debugging
Kenneth ks at geograf.dk
Wed May 23 16:57:10 EDT 2007
Always good to fix your own problems :D
The url you show, is probably for the Visual Studio 2005 Built in test
server.
Visual Studio 2005 has a small http server, that is used for debugging.
That would explain the odd port number. You should see a small icon for
it in the tray.
Logically, the MapGuide Viewer sample is not installed in the debugging
server, and thus you get 404 - Not found.
Regards, Kenneth, GEOGRAF A/S
Berdel, Brian wrote:
> I answered my own question again...I set the full path and eliminated
> the relative and it is now ok. I'll just stop talking today.
> Thanks.
> Brian  Berdel
> McMahon Associates, Inc.
> p: 215.283.9444
> www.mcmtrans.com
> -----Original Message-----
> From: mapguide-users-bounces at lists.osgeo.org
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Berdel,
> Brian
> Sent: Wednesday, May 23, 2007 1:41 PM
> To: MapGuide Users Mail List
> Subject: RE: [mapguide-users] .Net and Debugging
> They are all checked. Thanks though. That is not the problem, it is that
> I can start the project but I keep getting 404 cannot be found error for
> the viewer, no matter how I attempt to set the link.
> Brian  Berdel
> p: 215.283.9444
> www.mcmtrans.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kori
> Maleski
> Sent: Wednesday, May 23, 2007 1:40 PM
> To: 'MapGuide Users Mail List'
> MS Visual Studio 2005 Pro
> Tools > Options > Debugging > Just-In-Time
> Check all options.
> This will allow debugging (F5) to break on MapGuide code when an error
> is
> encountered.
> You cannot pause or set break points on the MapGuide code with this
> method,
> only break and view errors when encountered.
> Cheers,
> ________________________________
> Kori Maleski
> Senior Application Developer
> WEBSOFT DEVELOPERS, INC.
> P: (530) 759-8754 ext 114
> F: (530) 759-0923
> kori.maleski at websoftdev.com
> Brian
> Sent: Wednesday, May 23, 2007 8:58 AM
> I guess I didn't try every way...Attaching to the aspnet_wp.exe works,
> but I cannot debug using F5
> Brian  Berdel
> p: 215.283.9444
> www.mcmtrans.com
> Brian
> Sent: Wednesday, May 23, 2007 11:48 AM
> Subject: [mapguide-users] .Net and Debugging
> I have had trouble with this since I started with MapGuide...I have
> tried every possible debugging method in .Net and I cannot Debug.
> Has anyone else had this issue and if so have you been able to fix it?
> Development Machine is XPSP2 / VS 2005 / Mapguide 1.2
> Brian  Berdel
> p: 215.283.9444
> www.mcmtrans.com
> [mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Kenneth
> Sent: Wednesday, May 23, 2007 11:37 AM
> Subject: Re: [mapguide-users] OGR and MGOS
> I haven't tried that one. Basically, check the OGR website for what is
> supported.
> I have removed some of the dependencies that Traian includes, as I don't
> have them (OCI mainly, can't remember the others).
> Jose Manuel C G wrote:
>> Thk for the providers, Kenneth.
>> Does support WMS with 'queryable' layer?
> mapguide-users mailing list
> mapguide-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapguide-users/attachments/20070523/f7a4bb13/attachment.html
