[mapguide-users] Compile mapguide-1.2.0 on Fedora Core 6
Tom Fukushima tom.fukushima at autodesk.com
Thu May 24 01:21:38 EDT 2007
Hi Manuel,
When building FDO, you will need to build the SHP provider as well.  It
is available from
http://download.osgeo.org/fdo/3.2.2-Beta2/fdoshp-3.2.2_beta2.tar.gz.
I tried to get rid of this dependency but I believe some of the join
code uses it (Ronnie may have more info) and we didn't have time to fix
it up yet.
Tom
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Manuel
Ferreira
Sent: Wednesday, May 23, 2007 8:03 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Compile mapguide-1.2.0 on Fedora Core 6
Hi all,
I have successfully built Apache, PHP, FDO and MapGuide-OEM on Fedora
Core 6 (gcc  4.1.1).
But I cannot compile the MapGuide-Server on Fedora Core 6:
make
GwsFeatureQueryResults.cpp:27:42: error: SDF/IScrollableFeatureReader.h:
No such file or directory
GwsFeatureQueryResults.cpp:28:42: error: SHP/IScrollableFeatureReader.h:
GwsFeatureQueryResults.cpp: In member function 'virtual EGwsStatus
CGwsFeatureIterator::InitializeReader(FdoIFeatureReader*, IGWSQuery*,
CGwsPreparedFeatureQuery*, bool)':
GwsFeatureQueryResults.cpp:75: error: expected type-specifier before
'SdfIScrollableFeatureReader'
GwsFeatureQueryResults.cpp:75: error: expected `>' before
GwsFeatureQueryResults.cpp:75: error: expected `(' before
GwsFeatureQueryResults.cpp:75: error: 'SdfIScrollableFeatureReader' was
not declared in this scope
GwsFeatureQueryResults.cpp:75: error: expected primary-expression before
'>' token
GwsFeatureQueryResults.cpp:76: error: expected `)' before
'm_extProviderType'
GwsFeatureQueryResults.cpp:77: error: expected type-specifier before
'ShpIScrollableFeatureReader'
GwsFeatureQueryResults.cpp:77: error: expected `>' before
GwsFeatureQueryResults.cpp:77: error: expected `(' before
GwsFeatureQueryResults.cpp:77: error: 'ShpIScrollableFeatureReader' was
make[4]: *** [GwsFeatureQueryResults.lo] Fehler 1
make[4]: Leaving directory
`/root/mapguide-1.2.0/Server/src/Gws/GwsQueryEngine'
make[3]: *** [all-recursive] Fehler 1
make[3]: Leaving directory `/root/mapguide-1.2.0/Server/src/Gws'
make[2]: *** [all-recursive] Fehler 1
make[2]: Leaving directory `/root/mapguide-1.2.0/Server/src'
make[1]: *** [all-recursive] Fehler 1
make[1]: Leaving directory `/root/mapguide-1.2.0/Server'
make: *** [all-recursive] Fehler 1
I did't found the missing headers "SDF/scrollableFeatureReader.h" and
"SHP/scrollableFeatureReader.h" anywhere. Can anyone help me, please?
best regards
Manuel Ferreira
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
