SV: [mapguide-users] Any example how connect to ArcSDE fromcodewithFDO
Bjurström Jan
Jan.Bjurstrom at lm.se
Thu May 24 01:40:29 EDT 2007
Hello ArcSDE users!
Is there any success with modified code to use to connect to ArcSDE?
The server Ive tried (MGOS 1.1.0.301 and FDO 3.2 on Windows XP) is very shaky and creates a lot of gsrvr processes (19(!) for a WMS with 2 layers) that I can't see why.
Do you have other/better experiances?
/Janne
-----Ursprungligt meddelande-----
Från: mapguide-users-bounces at lists.osgeo.org [mailto:mapguide-users-bounces at lists.osgeo.org] För Brad Nesom
Skickat: den 23 maj 2007 18:09
Till: 'MapGuide Users Mail List'
Ämne: RE: [mapguide-users] Any example how connect to ArcSDE fromcodewithFDO
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=4144367
The sdk includes Autodesk FDO API Developer's Guide http://images.autodesk.com/adsk/files/map3d_devguides.zip
http://www.autodesk.com/map3d-skillbuilders
these may help.
-----Original Message-----
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of Brad Nesom
Sent: Wednesday, May 23, 2007 11:01 AM
To: 'MapGuide Users Mail List'
Subject: RE: [mapguide-users] Any example how connect to ArcSDE from codewithFDO
I don't have any code examples but one suggestion is to make sure you are not using the db instance name but the arcsde instance name. such as 5151 or esri_sde. I think there should also be some version parameters as default store is one option and any other schema that contain sde data could also be used and then the actual version name such as live or default or the version name.( I am thinking of what parameters I see in the FDO connection for arcsde in map) Hope this helps Brad
[mailto:mapguide-users-bounces at lists.osgeo.org] On Behalf Of bigtower
Sent: Friday, May 18, 2007 2:17 AM
To: mapguide-users at lists.osgeo.org
Subject: [mapguide-users] Any example how connect to ArcSDE from code withFDO
Hi everyone,
Somebody has an example about how connect to ArcSDE (FDO) from code. I use NET and I think that my problem is the string connection. I pass the server, the instance, the user and the password.
Please if someones has an example code in .NET about an ArcSDE connection I will be really grateful.
Thanks
View this message in context:
http://www.nabble.com/Any-example-how-connect-to-ArcSDE-from-code-with-FDO-t
f3776114s16610.html#a10677567
mapguide-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapguide-users
